Residential theoretical ? about "outlet"
Dweeber
All,
My question is in Article 100, the definition of "outlet". Is a blank-face GFCI with and L.E.D. indicator on it an outlet?
My search of older threads gave me too many results, and most of them I didn't fully get.
Thanks in advance,
D.
charlie b
Lockport, IL
Retired Electrical Engineer
I would say, technically, the LED is an outlet.
I would say instead that the presence of the LED is what turns the outlet box into an outlet. The LED itself is just a load. Indeed, if I were to try to be technical, I would say that the point at which the wires (having entered the box from the conduit) are screwed onto the GFCI/LED device is the "outlet." :roll:
acrwc10
Master Code Professional
CA
Building inspector
So does that make a fuse with an led indicator light "an outlet" ?
LarryFine
Henrico County, VA
Electrical Contractor
Well, technically, the box becomes the outlet because of the device installed in it, not the device itself.
don_resqcapt19
Illinois
retired electrician
I still don't see the indicator LED as making this anything more than a switch or a controller and do not see this point on the wiring system as an outlet.
Dweeber
Thanks to all that have replied. I was along the lines of thinking that it is a very minute detail, the L.E.D. utilizing electricity.
Believe it or not, I appreciate the excruciating exactness of critical thinking.
D.
