code
a 120/240 - volt, 3 wire , single phase feeder supplies a small panelboard
with four 2 wire branch circuits where the the cal load is 15 amp on each
ungrounded conductor. the min amp permitted for this feeder is ?????
and where in the code can i find this ?????????
George Stolz
Windsor, CO NEC: 2017
Service Manager
I see by your profile you are a signal tech. Are you studying for an electrical exam or something?
I would appreciate it if the membership would refrain from specifically answering this question until we understand the nature of the question.
charlie b
Lockport, IL
Retired Electrical Engineer
To George's comment I will add what has also been posted in your other two questions. We don't do anyone's homework for them. Tell us your answer, or tell us where you have looked for an answer, or tell us what you have tried to do to work out the answer, and we will offer you assistance. If you simply post a test or homework question and wait for someone to do your work for you, you won't get any assistance here.
tom baker
First Chief Moderator
OK here is hint to help you learn how to find answers in the NEC.
Start with the index. Look for an article related to your question.
Then read the scope (dot one) section of that article to see if it applies.
And understand the NEC is broken down into chapters, grouped by subject.
