I don't think I've ever seen anything quite as cryptic as the rules for running cables in cable tray. I have a question about cable spacing, and another question on the grounding.
I need a 600 amp feeder, so I'm assuming I'll specify two sets of 350KCM, 3 conductor, armored cable. Do I have to maintain a cable's diameter spacing between each cable? For example, if my cables are 1" in diameter, do I have to leave 1" of empty space between each cable per 392.11?? Or do I only need to do that if I'm calcualting ampacity per the engineering formula 310.15(C).??
If I don't leave the space between the cables, do I have to derate for 6 current carrying conductors? Or not since I only have 3 conductors per cable?
Finally, since I have a 600 amp breaker feeding these two parallel cables, do I need a #1 ground in each cable? 350KCM MC cable comes standard with a #3 ground. But doesn't the metal jacket count for something?
Steve
Steve
