Porcelain lamp holders -- all installs code violations?
lakee911
Columbus, OH
I see these things all over the place, closets, garages, basements, etc.
I saw one in its original packaging and read the box and I was surprised by a few things...
The lamp holder had a rating of 250V/660W. Isn't 150W the largest bulb that comes in this size lamp base?
It was also rated for 90degree wire only! Does this mean it can't be used with NM wire? I think that is the only type of wiring I've ever seen used with them.
Do you guys use them? If so, where and how?
Thx,
Jason
kbsparky
Delmarva, USA
Depending on the size and use of the closet, installing a keyless socket may be a violation.
As for connecting type NM wire, if you have type NM-B, which has conductors rated for 90C, no problem there.
We routinely install them in attics, garages, and unfinished basements.
Dennis Alwon
Chapel Hill, NC
Retired Electrical Contractor
What does the size of the closet have to do with it. Open bulb porcelain is legal in a closet as long as it is not a clothes closet.
jetlag
I know one use that is illegal for sure . I have seen them used for fuse holders and they will stand 30 amp . The 660 watts must be just for the heat because that is 5.5 amp at 120 v . People used to use them all the time as a fuse disconnect for well pumps out in the country. They would have 2 lamp holders for a 240 pump with 30 amp fuses. The pump was usually 4 amp @240 and the 30 amp fuse handled the start load fine . I even saw a whole garage apartment ran on 2 - 30 amp, that fed 6- 15 amp for the branch circuits. I also saw in an attic where someone tried to keep their #14 wire legal when they tied into a #12 20 a . They installed a lampholder with 15 amp fuse on the #12 line and came out with the #14 . Back in those days the out side shell was brass not aluminum :roll::confused::grin:
al hildenbrand
Minnesota
Electrical Contractor, Electrical Consultant, Electrical Engineer
Thanks for posting this. That's a new detail I had not yet noticed. This type of lampholder is so old it has its very own classification in the UL White Book.
The 90 degree C rating posses an interesting problem for all those replacements of existing worn out keyless and pull chain lampholders on old 60 degree wire.
lakee911
Columbus, OH
For sure. I did stop at Lowes the other day and looked at them. Cooper Crouse Hinds, I think, made the porcelain one I had seen. I did notice a plastic one, but it didn't have any instructions and didn't list a specific temperature. Maybe its different?
334.112.
The 'key' is a switch, so 'keyless' means 'without a switch', or 'does not have a pullchain'.
Ok--must be old terminology. I always thought the switch was turn a quarter counter-clockwise for off and a quarter turn clockwise for on. :D
I know one use that is illegal for sure . I have seen them used for fuse holders and they will stand 30 amp.
Oh, that's certainly interesting. I've never seen heard of that before. I didn't realize that the fuses had the same base on them.
Jason
kbsparky
Delmarva, USA
...The 'key' is a switch, so 'keyless' means 'without a switch', or 'does not have a pullchain'.
A keyed type lamp holder actually had what appears to be a key switch on it:
Lw6jqo79taEvWbq66HMEEZGyswOJj8acWRZx8j8qSmHq9adxSQluvnfp970YBMvorThSN_Kn_FnQJOH_nvaPZFU4AqwTBH6Mt7kiUcTZcsq8pm73TUBCns-GyuIWNt8-T6FSH6b1n-YqeQrwPfdMVCK-BsKXK5tHZ-7Rqcqlsxw
In the olde days, it was common to see this type of lamp holder hanging from a pendant in the middle of a room. One had to turn the "key" to make the light come on. Pull-chain types were later used, so the light bulb could be mounted closer to the ceiling ....
dmagyar
Rocklin, Ca.
That fixture is a thing of beauty
I wonder if that fixture is in the museum of modern art somewhere? :)
kbsparky
Delmarva, USA
I have always followed the notion that an open bulb keyless fixture in any closet should maintain sufficient clearances from shelves to minimize the hazards of starting a fire.
While the diagram in 410.8 is useful for any closet, some might say those provisions are not enforceable in areas where clothes are not stored. To those nay-sayers, I refer them to 410.5. Just good common sense here.
