Do you have to ground the sprinkler pipe. If so what code number??
I've said the same thing about gas piping. Supposedly, the gas line has an isolating joint in it.Not sure how you accomplish bonding without it becoming an electrode.
Wouldn't the sprinkler pipe be already bonded by default due to it's means
of installation. Usually hung by beam clamps & all thread. Granted beam
clamps are not rated to carry fault current.
Sprinkler pipes are unintentionally bonded in many places esp. when pumps are involved. However the fire code, I believe, as Gus is referring to, may have a say in bonding the pipe.
Why do you say that. If there is no dielectric fitting to separate their pipe from the interior piping and being used as an electrode, then I believe they do have a say. The gas companies wont let you bond their pipe coming in from the street.Good point.
I say they have no say in bonding. They may as to 'grounding'.
