Adding grounds rods to either a fence or a rail makes as much sense as adding them to ships at sea, airplanes, and space craft.
I mean- just where will the electricity go,and how will a ground rod help clear a fault?
The only place electricity wants to go is 'home,' back to where it was made. In the case of power lines, that's back to the last transformer.
If, for some reason, you have current induced into a piece of metal and you want to get rid of it .... about all you can do is put a resistor in the circuit and burn it off.
