I wonder, what is the difference if you find someone who has achieved that rating? Bottom line is, if you are a proper contractor, you should have the means to measure the rod's resistance really easily. Once you do, if you do not achieve the criteria, then you have to drive another rod to do so. Alternatively you can just drive more than one in any case.
I'm not trying to discredit your question as a fun fact to know, but I doubt it has any practical outcome on any installation you may do or encounter.
I have never even seen a FOP resistance tester in the flesh, much less used one. :roll:Bottom line is, if you are a proper contractor, you should have the means to measure the rod's resistance really easily.
Is their anyware in USA that you can 25 ohms or lower on a 8' ground rod driven in earth?
101208-1118 EST
In my yard and at the shop I have less than 25 ohms. From memory in the 10 to 20 ohm range. This is a clay loam soil and generally there is moderate moisture present below a few inches.
In our part of the country we have green foliage as compared to somewhere like Colorado.
The clamp tester is almost junk IMO.
Unless the test is done perfectly it is mealiness.
Zog has posted many times about the clamp meters short comings.
I believe that one 20' copper ground at each pole is enough. They are all connected together with a #6. All 196 of them
I can drive a whoooooooole lotta ground rods for the cost of the proper test equipment and the labor to conduct the test.
And in most cases, especially residential and small commercial projects, that will suffice but, on projects that have specific GES performance specs the tests must be done, and if the permitting process of the particular area includes plan review it can become part of the inpectors requirement for the final.
Roger
And I make money doing this, SO TEST AWAY PLEASE!!!!
101208-1118 EST
