Is CCST the flexible yellow stuff? If so, it 's not a part of the line.
Actually the HI noted that it was not required, but that he highly recommended it for lightning protection.
The people I am doing the work for have already purchase the 2.5 million dollar house, and want everything perfect.
Thanks for the replies and the 250.104(b) reference.
Yes CSST is that yellow stuff, and when I see it or know it will be installed I up charge for the extra bonding requirements.
As far as protecting from lightning, I tread the ground very lightly around this subject, as very few requirements in the NEC if any will do anything for lightning prevention, even ground rods, there have been test done at Camp Blanding, Fl. that prove NEC required ground rods are worthless when it comes to lightning, as they also do nothing in the areas of protecting against shock hazards touch hazards, or much of anything in a house, so to me if you like sticking tooth picks in the Earth go for it, just don't expect it to protect against a lightning strike.
With that said, when I'm directed by another source to put in any ground rods, I try to make it clear it will not protect from a lightning strike, I don't want anyone thinking that it will or expect it too, I do this because I don't want a home owner coming back after being hit by lightning and trying to pin down against me that it should have, so I make sure it is understood it was not my recommendation.
For more info read this post
http://forums.mikeholt.com/showthread.php?t=77454&highlight=%22camp+blanding%22
