Or they think they can get a code requirement put in place to require this thing without any proof it is needed.
No, we are not involved in some conspiracy to get the code amended to require our new product to be used.:roll:
It was developed solely as a better solution to the KC. While the pricing may be a little high, over time we hope to be even more competitive (volume manufacturing). It certainly is simpler in design - only using a set screw, body, and a locknut to achieve the same thing as the KC's 5 components.
The KC was developed not to 'replace' the GEC bonding connection between the tub and the neutral bus, but to 'augment' it. Apparently, many AHJ's agreed as they seem to be required in many installs.
Our MC series fittings are listed for the application as required in 250.8. Unfortunately, an NM strap connector (like the 650-DC) is not listed for that purpose. ....and I know....thousands of electricians have been using that fitting for eons without anything ever blowing up... I have also seen the 650-DC used as a feeder splice clamp - instead of a split bolt or other approved means.
