2011 nec pdf
donselectric
nh
anyone have trouble using the pdf version on 2011 code?
i was able to d/l the free ver from the code book i bought
it worked once then i get "you already activated this"
then i found out it dont work with adobe x so i uninstalled x and went back
to nine. same issue
anyone have a fix
thanks
Dennis Alwon
Chapel Hill, NC
Retired Electrical Contractor
There is no fix that I know of and some other member said he had trouble opening other pdf files that were on his computer. So it is not an NEC problem but an adobe X problem. I bet they will have a fix for it eventually.
George Stolz
Windsor, CO NEC: 2017
Service Manager
I didn't have adobe x and it did it to me. The OP will have to email NFPA, and they will set it up so you download the NEC again and start fresh.
Try not to open it again once it's working. ;)
Dennis Alwon
Chapel Hill, NC
There is an 800 number on the card to re-download but I didn't need to re-download when I deleted X and installed 9.4 or so.
