ZinskI/E
- New Orleans, LA
I would like to comply with NFPA 70E as well as protect myself and fellow workers when testing for live circuits. The standard is that a meter be checked against a known live source of comparable voltage, the circuit to be worked, and then against a known source again. This can be inconvenient when working in a remote or not-easily-accessible area, or can create an unsafe condition by opening gear or equipment to find an acceptable voltage against which to test a meter's operation.
I have used non-contact voltage testers for 'mushroom heads,' but would like to know if a direct contact, portable voltage generator exists for voltages from 50VAC to 480VAC. In other words, I'm looking for a small, portable, battery operated device with an adjustable AC output. The only load to be served would be a high impedance multi-meter, so power draw would be a minimum.
The device does not need to be IS. If such a tool is out there, please point me in the right direction. If not, does anyone have ideas on how to create such an implement (preferably using readily available parts!)?
