shamsdebout
- Macon,GA
I am working on LEED builder with a lighting designer who said Track Lighting was exempt from Ashrae 90.1 lighting power density calculation if the track lighting was used for ambient lighting. Has anyone ever heard of this?
If it isn't then we would need current limiting breakers in the track lighting feeds or Juno Lighting seems to a sub panel based solution which they say is cheaper than individual current limiters for each run of track, it comes with current limiting breakers installed.
Would appreciate comments on if you have been able to avoid including track lighting in your energy use calculation on a LEED building.
Thanks,
Thanks,
