110202-1128 EST
electrics:
I do not have time to create any scope photos for you at the present time. Someone else may be able to create some for you.
But I will try to verbally explain a little further.
1. From the 50-60 Hz mains you connect to a bridge rectifier, 4 diodes configured in a bridge type arrangement.
A bridge rectifier has two anodes connected together and two cathodes connected together. The paired cathodes are the positive polarity output, and the paired anodes are the negative polarity output. The remaining cathodes and anodes are connected so that a cathode connects to an anode. Then these cathode-anode pairs are connected to the AC mains.
See
http://en.wikipedia.org/wiki/Diode_bridge
2. Across the bridge rectifier DC output is a large capacitor to reduce the ripple content of the rectified DC.
Now you have a DC source somewhat the equivalent of a battery.
3. If I chop a DC source on and off I have generated an AC source. But it has a DC component.
I could do this with a mechanical switch. This mechanical switch could be a round shaft with a copper conductor on one side and an insulator on the other side. This shaft mounted on a motor and two brushes contacting said shaft will produce a fast switch. It could be 60 Hz.
If I build a more complex switch, then I can remove the DC component. This would be desirable.
With an AC signal I can use a transformer to isolate and produce any desired output voltage.
3. If instead of a mechanical switch I use electronic components to create the switch, then I can switch at much higher frequencies.
See if this helps to this point.
In what country are you located?
