goldstar
- New Jersey
- Electrical Contractor
Just want to bring this to eveyyone's attention seeing as how I recently got tagged for this on a kitchen remodel. The ceiling rafters at this project were 2" x 8" construction, 12" on center. I used (8) Juno 5" non-IC cans as there was no insulation going into the ceiling, and (4) 5" non-IC remodel cans in the dining room (existing sheetrock). I had about a 1/8" clearance above the can but the inspector cited 410.116 stating that there had to be 1/2" clearance between the can and the flooring above if I'm using non-IC cans. This section of the NEC clearly states that and (for the most part) I can understand and see the logic of the ruling. If you're using 6" non-IC cans you can use up to 150 watt bulbs in the can and I'm sure the can could possibly get quite hot (though I can't imagine it could get hot enough to burn through the can and then through the flooring above). In contrast, a 5" can restricts you to a 65 watt bulb, irrespective of whether you use an IC can or not. I think this section of the NEC needs to be re-examined and redefined in cases where the can restricts the bulb wattage.
I changed out the remodel cans and replaced the new work cans only and left the nail-on framing in tact. Took me about 3 hours to change out 12 cans.
BTW, I'm also writing a book on "How to bid jobs real close and then lose money when you have little or no work to begin with". :grin:
