I was approached by my mechanical engineer to consider re-size of the cable of a motor as they?re thinking of getting a new motor for this pump and the new motor will be 125HP, whereas the old motor is 75HP. Below are the specs I found from the existing MCC design:
Motor Volt FLA Cable Cable Ampacity Upstream Breaker
125HP 460V 182 1-3/C #350kcmil 350 400AF/225AT
75HP 460V 109 1-3/C #4/0 260 150AF/150AT
The FLA is calculated FLA assuming 0.8PF and 0.8 Eff. Cable ampacity is based on NEC table 310.16 assuming temp. rating 90C.
Before I suggest to my mechanical engineer to go with a 3/C #350kcmil cable system (as the case for other 125HP machines on the same existing MCC), I want to understand if it is possible to utilize the existing #4/0 size cable as I feel its ampacity seems to be able to adequately accommodate the new 125HP motor. It?ll make a huge cost difference if we have to re-size and install new cables.
I?m not as familiar in the sizing of cables, so my questions here are: are we able to use the existing 75HP cable system to accommodate the new 125HP motor? Also, what was the basis of determining the size of the cables as you can see that for the existing 125HP motor, our #350kcmil provides some ampacity reserve. Pretty much I want to know what's the math/calculation behind the specs that as shown above.
Thank you.
Thank you.
