as far as the NEC is concerned, unlimited. As far as your pull rope, string, etc will allow and as long as your pulling tension won't damage the conductors.
stepped on Bob.,,, his answer is better
I would imagine about 24,859 miles because at that point you will likely have reached 360 degrees of bend.
Don'r forget to include box offsets when counting those bends!
It used to be 100 feet back when we had 110/220 volts and the high leg was 190 volts.what is max. lenght of conduit run before u have to put j-box in
It used to be 100 feet back when we had 110/220 volts and the high leg was 190 volts. ............
I don't know, but the guys with the antique NEC's should be able to tell us.Was that an NEC requirement?
Perfect answer Bob.
I have been on a few over 500 feet. They can go easy or hard depending on pipe fill,size,lube, number of bends and most of all how head was made and who is feeding it..
Just keep in mind you got to be able to pull it in.
That would depend on the size and material of the conductors.Vertical risers need conductor supports, so you may be limited to 35 feet before a jb is required
But not for splices or junctions.... just support of the conductors.
