dm9289
Industrial Maintenance Electrician
- Pennsylvania
- Industrial process repair/ maintenance Electrician
I was reading thru the monthly highlights and one of the threads talked about installing a fan and not having a ground connection but being wired with 2 wire BX cable and it got me to thinking. In my region there is alot of bx some with the extra thin bare wire in it and most without. Primarily what was done with this at receptacles was to ground receptacles to the box utilizing the BX case for a ground. When a home inspector comes with his plug tester it analyzes the plug as correctly wired and grounded and goes on the report as such and apparantly many home flippers have caught on to this.Also when you test with a meter hot to BX case you will get 120v. I was always under the impression that this practice was against code but I could not find a reference for it, does anyone know chapter and verse? More importantly what is the safety hazard in doing this if the case continues to the box properly? What is the danger when the BX case is used and not continuos to the box?
