Ridgeback125
New member
I?m currently removing equipment in a Telco Central office. We use -48v power feeds with an integrated ground plane. My question is I need to lead verify the grounds to make sure that they where installed correctly so I don?t knock out service to a working system. I get .02mV with a VOM if I use a Clamp on amp meter will it do me any good to help verify the correct leads? The equipment to be removed has been fuse down so on the -48V leads I get 0V with my VOM. Please help I don?t want to get fired!!
