justdoc
I was taking a small refersher course on a site and saw the wording a 120volt circuit has a breaker ,a hot wire , a neutral, and a ground
I have always been told and taught and read that the neutral carries the the unbalanced load between two hots/circuits
I was always taught that the 120 circuit was a hot, a grounded conductor and a ground
Has this changed is the white wire now being called the neutral on a 120 volt circuit or when would you use a neutral in a 120 circuit ?
This course is on a very well known site and their products are widely used so I am confused about the neutral in their statement
I did write the folks and ask them about this and did get a reply
"Thank you, CXXXXXX, for taking your time to email me. There is indeed a neutral in a 120 circuit. It may or may not be used but it is there."
Maybe I have been away from the office to long
Thanks
Justdoc
Thanks
Justdoc
