Type AC cable vs FMC
VIC1958
Is a seperate grounding conductor needed on both of these or is the outside metal sheathing considered the grounding conductor? Does the mfg have to state somewhere on the package that the outside sheathing is an acceptable grounding conductor?
augie47
Tennessee
320.108 provides that AC shall be provide a adequate ground path.
348.60 for FMC references you back to 250.118(5) which places limitations on FMC's ground path including a 6 ft limit, as rcarroll notes
