1-83 Log #2220 NEC-P01 Final Action: Reject
(110.16)
_____________________________________________________________
Submitter: Donald A. Ganiere, Ottawa, IL
Recommendation: Revise as follows:
11 0.16 Flash Protection. Switchboards, panelboards, industrial control panels, meter socket enclosures, and motor control centers that are in other than dwelling occupancies and are likely to require examination, adjustment, servicing, or maintenance while energized shall be field marked to warn qualified persons of potential electric arc flash hazards. The marking shall be located so as to be clearly visible to qualified persons before examination, adjustment, servicing, or maintenance of the equipment.
Substantiation: The requirement that this be a field applied label is left over from the original proposal that called for the label to contain arc flash information that was specific to the installation. Now that only a ?generic? warning tag is required there is no reason that it must be field applied. The warning label will have the same effectiveness whether applied in the field or applied by the equipment manufacturer.
Panel Meeting Action: Reject
Panel Statement: The panel concludes that marking of every item may weaken the safety aspects of the marking to warn qualified people where the instances of exposure to arc flash hazards are pronounced. Equipment manufacturers will not know if their equipment will need to be maintained while energized in a particular installation, therefore necessitating field marking. Also, the requirement in 110.16 applies when changes are made to existing equipment.
Number Eligible to Vote: 12
Ballot Results: Affirmative: 11 Abstain: 1
Explanation of Abstention:
FISKE, W.: We are abstaining from voting on Proposals 1-82, 1-83, 1-84, and 1-85, as they relate to field marking of arc flash hazards. There is no role for conformity assessment bodies (i.e., nationally recognized testing laboratories)
to play in fulfilling the existing or proposed requirements. As we are not an affected party, Intertek has elected not to take a formal position on the four proposals identified above.
