Time Hog
Time Hog
I don't have much to offer in the way of product suggestions, but I've used MS Project before. The upside of PM software is that creating projects helps focus you on the various tasks needed to get the overall job done. As you build the job in your head, you can see where the various elements affect each other. If "slab cure" has to be 28 days, you know when the pour has to happen in order for the switch gear to get dropped by June 15th. On the other hand, if you put 300 tasks in your project, you have to track them. All of them, or else the downstream utility of the software is lost (project post mortem, lessons learned, true costs). You can easily find yourself spending half a day or more just keeping track of all your tasks. If you have 5 or 6 jobs going, you may find yourself with a full time scheduler on the payroll. If you don't want to boost your overhead to that extent and your jobs are small enough and similar enough, maybe creating detailed job check lists and making it the foreman's responsibility is the way to go.
