So after the whole powerbridge post, I have come up with a question. Although I did not read every post in that huge thread, I read enough to see that one of the main objections to the product was that flexible cord was being used as a replacement for a chapter 3 wiring method, since it was a ?permanent? installation.
I also know that it was found that even though the product was listed as an assembly, since the cord is not compliant with the NEC, the product cannot be used compliantly. Basically saying that everything installed must meet all standards of the NEC, and the listing is not necessarily applicable.
Now, I thought I have read for years on this forum that listed products can be built to standards that are different than the NEC, but since they are listed that way, they are compliant to install. Some examples that include flexible cord:
*Gas direct vent water heaters that come with a cord and plug for connection. This is an appliance that will be installed permanently for 10 years?way longer than any home entertainment setup. It is permantly crimped/soldered into place. The units are listed and intended to be plugged in straight from the manufacturer. Since this is an NEC violation, what are you supposed to do? If the unit was listed to be plugged in, you can?t modify it and hardwire it. There is no provision in the NEC that I know that allows this installation, such as those found for dishwashers and garbage disposals.
*Industrial machinery that was built and listed in a panel shop. I have seen tons of flexible cord used in this setting where a chapter 3 wiring method could have easily been used?even where flexibility, portability, serviceability was not necessary. But since it is listed, it is ok??
I know I can come up with more, but I am confused as to when a listing can override the NEC and when the NEC can override a listing.
Thanks!
Thanks!
