rpetrovski
I have a corner tapped Delta feeding a 480 to 240/120v single phase control transformer. On the Delta it is 480 to ground on all phases but the center tapped phase which is 0. Can this cause problems with the the control xmfr? I keep blowing fuses on the line side of the xmfr. The voltage and aps look ok when I replace the fuses. It only happens when the power to the xmfr is cycled. Could this be caused by inrush to the xmfr?
