jmellc
- Durham, NC
- Facility Maintenance Tech. Licensed Electrician
I drilled a few holes in concrete walls for a friend doing cabling. Inch and 1/2 holes. After 1st hole & creating so much dust, I came up with a better idea. I started my hole a bit, cut the top off a kitty litter jug & taped it to the wall, mouth of jug outward, lower end lightly taped, allowing for movement.
Set bottom of jug on floor, close under the other part. As I drilled, the dust/grit dropped easily in the shield. Every 1 or 2 minutes, I pulled out on the bottom & it fell to the bottom. Had paper on floors too, roll the dust w paper & discard.
This worked great. A quick sweep or vaccuum cleaned up well.
