carnes51214
We are installing 480v A/c disconnects. From disconnect to A/C we are using sealtight flex. One side is concentric and the other is not. We do have a equipment grnd in flex. My question is being 480v do I still have to put a bond bushing on the concentric side even if I'm using a equipment grnd conductor. Or is it actually required on both ends because sealtight metallic is not suitable for equipment bonding as is emt and rigid.
Another question on similiar lines is I have a 1 1/2 greenfield flex from panel with is no concentric knock out but to disconnect on bus duct is concentric. Do I need bond bushings on both ends or just the end with concentric knock outs.Also 480 volts.
