I've been in a discussion with an electrician friend of mine about what constitutes a "sub panel" and whether these neutrals should be isolated or not. I have my opinions and he his. I'll see if I can explain this correctly.
It?s not uncommon to derive power from a Traffic controller for additional equipment added to traffic systems installed internally or externally.
These systems don?t always have a metered service, power is brought in and connected to an internal lug/main breaker that will supply power to a breaker pack. Because of the sensitivity and possible conflicts? to some of these systems, it was suggested power to be taken before the main breaker for adding on to system.
Lets say you take power source directly from incoming power lug before main disconnect in first cabinet and use it to supply breakers in a second cabinet. Does this define new cabinet as "sub" or "Main??
I say sub and therefore neutrals and grounds should be isolated but he says no. Because the power source is taken before the main disconnect in the first cabinet, it is now considered its own main service. I do own the 2008 NEC but have not found reference yet.
