vinod
- Saudi Arabia
Can anybody give me the explenation of CL fuse?
Your help will highly appreciated.
Current limiting.
No, they don't cause any change in the short circuit rating of any component. Rather, they allow you to use a component for which the short circuit rating is too low for the conditions present at its location, by providing a separate method of limiting the short circuit current to a value that is below its rating.
You can go here: http://www.cooperindustries.com/con...ry/selecting_protective_devices_handbook.html and register for a free disgest and find out more about fuses than you ever wanted to know :grin:
You have to be very careful tying to use current limiting fuses for that purpose. If the device you are trying to protect has an OCPD, then the only way to use the CL fuse is if they are a part of a listed series rated system.No, they don't cause any change in the short circuit rating of any component. Rather, they allow you to use a component for which the short circuit rating is too low for the conditions present at its location, by providing a separate method of limiting the short circuit current to a value that is below its rating.
