First, keep in mind that NEC is not a design standard, it is a Code Book to provide minimum requirements for safety.
With that said, no, standard IEC cables are different sizes (mm^2), and are typically installed by different methods.
You will need IEC cable ampacity tables for your installation type. Check with an IEC cable supplier for the info needed.
