Sure was leaking! When I got my gas fitter's license, we studied a chart/table that showed how long it would take for a gas leak to fill up a certain amount of square footage to an explosive level. There is a great difference in the rate with a 2 PSI nat. gas system vs. the (old) 1/2 PSI system. In that short amount of time between when the work was done and the explosion, it must have been a busted fitting, valve left open, etc, instead of a small leak which in some cases would not be found for days/weeks. Of course it takes a lot longer with natural gas (lighter than air) than propane. This is something that could have been prevented if the DIY'er involved would have tested the gas fittings with some soap solution. I'm surprised no one smelled the gas (odorant).
