Alwayslearningelec
- NJ
- Estimator
Ok so I am doing some studying/reading tonight and I see that if using conduit with a flush mounted box you must bond the receptacle to the box. If using a surface metal box this is not necessary because of the metal to metal contact of the yoke and box. If a raised cover is used you must use a bonding jumper . Not sure why though. There are receptacles now with special screws and yokes that provided and effective bond.... So my book says. Thanks
