I have a Eaton/ Westinghouse HDG 3400f circuit breaker with a kt 3300t trip unit. Its a 400 cb with a electronic trip unit rated for 300amps. This cb controls a vfd for a pump motor that is only drawing 195 amps and will las t for about 30mins when the cb trips. I put a amp meter on it while its running with a min/max setting and meter never records more then 195amps. Motor is said to be rated 135 hp at 480v. There is no shunt wiring that i can see. Unit is inservice for at least 2years.
Does anyone if these trip units fail or have a bad history, anything?, they are electronic units
