Backfed Lighting
rossjerry5
New member
Washington, NC
I am installing a switch and new light to existing light which is already powered at light box. I have 120V at light and ran a new 14-2 wire to new switch. How do I back feed new light. Existing light has a switch on light to turn on and off.
John120/240
Olathe, Kansas
See if I understand; You have power in the cieling, single pole wall switch; &
want to control other fixtures. At the switch black on one terminal & white on
other terminal. At cieling white that goes to switch ties to power & stuff in
back of box. Black from switch ties to fixture. White on fixture goes to white
that is in same romex as your power. Other fixture just tie in to black & white
at your fixture. Good Luck If you have a pull chain on your fixture I would make
sure fixture is on then cut the chain. Remember to turn off the breaker.
Dg01501
worcester
if your following the 2011 code then you need a neutral as well at your switch, ud have to run a 3 wire to your switch from your light, black and red for feed and switch leg and white for neutral, if not used on the switch then simply cap it off
John120/240
Olathe, Kansas
rossjerry5, How did the job go ? Did it work ?
Dg01501, correct you are. But for rossjerry5's situation the explanation was
satisfactory. I think this is in his own home.
If it is a conduit installation no neutral is required as it can be added at a later
date.
