sump pump in unfinished basement
domnic
Electrical Contractor
can i use a single recepticle for a sump pump in an unfinished basement
or must i use a gfi?
infinity
New Jersey
Journeyman Electrician
If you're in New Jersey the single receptacle without GFCI protection is permitted. As Bob mentioned the GFCI requirement is for 15 and 20 amp, 120 volt devices. You could go to a 240 volt pump and use a non GFCI-single receptacle also.
