Hello,
I'm familiar with VFD's, but have never actually used one. I am trying to help someone who is using the MVX9000 as a single to 3 phase converter for a wood shop.
The tool we want to power has a magnetic starter. I have read that it's best to wire the VFD output directly to the motor and remove the magnetic starter from the circuit entirely. He tried leaving the magnetic starter in the circuit and says he hears a clicking sound from the starter when he attempts to start the tool.
First question: is there general agreement that it's best to just wire directly to the motor and remove the magnetic starter completely?
After reviewing the MVX9000 manual (http://www.galco.com/techdoc/chgp/mvx9000_um.pdf) I'm confused on using the digital inputs to start/stop the VFD. Page 3-6 shows the Control Terminal Wiring (Factory Settings). I only glanced at the drive when I was physically in front of it, but I did not see any wiring on the control terminal at all. I think the drawing is indicated that connecting DI1 to DI6 will start the drive and removing the connection will stop the drive. I did refer to section 30.11 as well, but it did not clear up my confusion.
Second question: to start/stop the drive do I just need to close/open a connection between DI1 and DI6, or is there more to it than that?
Any help you guys can provide would be greatly appreciated.
Thank you.
Thank you.
