Wire size for heater
Sierrasparky
USA
Electrician ,contractor
Hey just curious as to what others think?
what size wire (Cu) is minimum requirement for a 4,000 watt wall heater. No derating issue for voltage drop.
Sierrasparky
USA
Just as I thought! 30 amp minimum wire ampacity and standard breaker size. I was asking because where I work mostly we use electric for heating. TIme and time again I see 4,000 watt cadet heaters on a 20 amp circuit. Sometimes I see melted connections.
petersonra
Northern illinois
engineer
4000/240=16.7 amps.
It should work fine on 20A circuits without melting the connections. If you are melting a #12 wire with under 17A load, there is something else wrong.
I agree it should be sized as a continuous load so it can't legally be on a 20A circuit.
