AWG code for 100amp subpanel
hardworker
What does code say about using #3 awg copper for the hots, #3 awg copper for neutral and # 8 awg copper for ground on a 135 ft run between the main and this 100 amp subpanel?
infinity
New Jersey
Journeyman Electrician
With 75? C terminations the NEC says that your installation is code compliant. Is someone saying otherwise?
augie47
Tennessee
I will note that, although it is not a NEC violation, at 50 amps or greater you will be exceeding the recommended voltage drop with a #3.
petersonra
Northern illinois
engineer
can't say there is anything "wrong" with it code wise.
might have VD issues at high usage times.
presumably you have done a load calculation and this installation is adequate to support that.
is the main 100A as well?
don_resqcapt19
Illinois
retired electrician
That would be the case assuming a 100% unbalanced load. With a balanced load and or line to line loads the current can go up will out exceeding the voltage drop recommendations.
hardworker
The main is a 200amp panel. The building owner was worried about voltage drop on the 135 run. The 100amp sub will never pull more than 70amp.
