ohmhead
- ORLANDO FLA
Well question art 250.122 (B) As shown in the example the step by step formula is fine i see how this is done .
Now my question is for what reason is this based on .
Why is this important to change the size of the grounding conductor if the breaker is sized at 300 amps and the wire is larger than needed but not due to voltage drop lets say you had a larger wire and used it no voltage drop issues .
What is the main reason for this section in the NEC ?
