Jimmyboy
- Dutchess County, NY United States
I am installing a 200 amp automatic transfer switch in a customers home, (along with a 17k Generator)... Unfortunitly, I only have a limited work space (utility closet) 36"w x 86"h x 7"d. I want to leave the existing 200 amp panel where it's presently located, and mount the new transfer switch below the panel because I have no space on either side. With 6 inches between the bottom of the panel and top of transfer switch, the clearence from the floor to bottom of transfer switch is 12 inches. Is this okay? Not sure if this makes a difference, but this is also a finishes basement. Any help would be greatly appreciated. Thank You in advance.
