Jimmyboy
- Dutchess County, NY United States
Installing a 17kw generator / automatic transfer switch for a customer. Unfortunitly, the customer had installed one 2"PVC pipe underground at the same time they had their in-ground pool installed and now due to landscaping/stone work, adding a new pipe is impossible. From Generator location to Transfer switch location is 100 feet.
In the 2" pipe, I obviously need to run the generator feeders, but I need to have 3 other lines (120vac for battery charger) and 3 low voltage lines (maybe #12 thhn also) for start/stop ect.
Can anyone tell me exactly what the code is for this application?
From what I understand, I can put the low voltage in the same conduit, as long as the wire has a 600 volt rating.... but I heard there may be a maximum distance they can run together???
