flengineer
- Miami, FL
I have an ATS that is protected at both the normal and emergency line sides. I am feeding a MLO panel from the load side of the ATS. I know the cable is protected by the OCPDs on the line side, but is it good practice to provide a disconnecting means or MCB at the panel on the load side? To disconnect power to the panel, I would need to open the breakers at the generator and the normal power. Do ATSs normally have a way to disconnect the load side?
