Hopewell
- South Bend,In
What is the minimum size conductor that is permissible to be used as a bonding conductor from a half inch diameter ground rod to flare stack (used to burn ?off/ incinerate off gases) that is 30 feet long by 2 feet in diameter?
Are conduit beam clamp permissible to be used as bonding clamp?
