240v debate....
jim dungar
Wisconsin
PE (Retired) - Power Systems
But in the end, it does not matter so much how we choose to describe them. For example, I can say two sine waves are 180 degrees out of phase with each other, or I can say they occur simultaneously and reach their oppositely-signed peaks at the same moment, and it does not matter which of these I choose to say. So long as we take care in the choice of reference points, choice of positive and negative signs for voltage measurements, choice of positive and negative directions of current flows, and other related choices, then two seemingly different descriptions can both be accurate descriptions.
My point is not how they are described, it is how they relate to the physics of the real world.
Faraday's Law of Induction, basically says a magnetic flux creates a voltage. The 'Right Hand' rule is often used to explain the relationship between a magnetic flux and the current it generates. Fleming's Rules (right and left hand) describe the relationship between a voltage (emf), the direction of the flux, and the motion of the conductor versus the field. They relate specific directions to the voltage, flux and current involved in a single core, single winding transformer.
jim dungar
Wisconsin
EEEEE-ther, EYE-ther, KNEE-ther, NIGH-ther! What say we call the whole thing off? :happyyes:
That is more like Van+Vnb=Van-Vbn=Van-(-Vnb)=-(-Van+Vbn) ad infinitum
By the way, which part of this long discussion has said this application of math principals is wrong?
I have been asking how a single magnetic flux can yield multiple voltage directions in a single winding on a single transformer core.
Which "rule" would I use to model this?
Maybe it actually is time to post this question in a new thread?
pfalcon
Indiana
Haven't you been eaten by a Morlock by now?:p
That's tomorrow.
Gentlemen, math only. I may be a low level grunt, but I want numbers-not words.
Yes, you may tell me to take a hike.
Seconded.
In post #433, you claimed
"that your circuit, as drawn, is wrong."
Please post what YOU think is a correct version.
Without dancing around the topic.
I can't see your diagrams for some reason :(
Engineering Calculations as a new thread.
mivey
But does not the polarity control the direction? Choose which flow you want, electron or conventional, does the polarity not control the direction in which the electrons flow?
Polarity only tells you what direction they flow relative to flow in other parts of the circuit at a specific point in time. Polarity does not tell you in what direction you must use the voltage force.
mivey
Since current flows from a higher to lower potential, we can use the standard convention that the positive terminal of a source is the one out of which current flows to a load and the negative terminal is the one into which current flows from the load. Now consider Besoeker's pulse circuit with terminals a, n, and b where a is the top terminal, n is the center-tap terminal, and b is the bottom terminal.
When a has a higher potential than n, the current flows out to the load from a and from the load into terminal n. When a has a lower potential than n, the current does not flow in that half of the winding.
When b has a higher potential than n, the current flows out to the load from b and from the load into terminal n. When b has a lower potential than n, the current does not flow in that half of the winding.
Thus, we label the terminals a & b the positive terminals and n the negative terminal. The voltages rises from negative terminal to positive terminals are out of phase by 180 degrees.
What's so hard about that?
jim dungar
Wisconsin
This only works when there is a neutral conductor. If there is no neutral conductor are you saying current only flows in half of a single winding center tapped transformer? How do you explain the current flow in 2-wire circuit fed from a 3 terminal transformer?
Besoeker
UK
Nobody is suggesting that anything extraordinary is going on with the flux. The simple fact (yes, fact) is that, for the single phase centre-tapped transformer, Van and Vbn are mutually displaced by 180deg.
See post #333.
Besoeker
UK
Flemming's left and right rules generally relate to (DC) motors and generators respectively hence the thumb for motion. One wouldn't ordinarily expect much motion within a transformer under normal operating conditions.
jwelectric
North Carolina
So what you are saying is that an AC transformer that has a center tap will only have direct current flowing in one half of the transformer at one time and will never alternate.
jwelectric
North Carolina
See post #333.
Does this mean what you said in the post above where there is current flowing from A to neutral point and from B to neutral point at all times but never current flowing from A to neutral point at the same 1/120th second that current is flowing from B to neutral point?
I think I?m beginning to understand this so please don?t stop explaining
mivey
There is no point in making silly statements like this. You and I both know that is not true.
It is a series circuit. A two-terminal circuit (the 3rd terminal does not enter the picture for the two-wire circuit) is not the same as a three-terminal circuit.
mivey
This site here explains it fairly well:
http://www.allaboutcircuits.com/vol_2/chpt_10/1.html
About half way to the bottom.
And if you can see that, I'll say you & I are in agreement up to this point like I think Rick & I are in agreement up to this point. Jim should be, but I really do not know if he can agree that you can have two 180? displaced sources without playing math games with the terminals.
As for polarity vs. direction, I made some water flow graphics that may clarify for those who can follow water flow easier than electric theory. The first shows two pumps connected in polarity and the second shows two pumps connected in opposite polarity. You should be able to follow the graphics and see that while polarity and direction are related, they are not the same thing.
Same polarity:
Opposite polarity:
mivey
I'm certainly not. The problem is that the others are trying to make the laws dealing with flux and voltage say something that they do not say.
mivey
With the circuit that Besoeker has, the load current in the winding halves will only flow from the center to the ends of the windings and will never flow from the ends towards the center-tap. One half will flow in one direction and the other half will flow in the other direction.
That is not the case without the diodes.
mivey
I think I’m beginning to understand this so please don’t stop explaining
I made some water wheel graphics that illustrate Besoeker's circuit.
This is his circuit with the pumps in polarity. You will notice that the water in the top half only circulates clockwise and the water in the bottom half only circulates counterclockwise. That is because of the one-way flapper valves (diodes). It might be hard to see at this resolution but the flapper vales pivot on the left side and are open on the right side.
Here is the same circuit but using pumps connected in opposite polarity:
jim dungar
Wisconsin
You simply refuse to acknowledge the physics of a transformer, because it conflicts with your position that the circuit should be solved using the neutral point to define voltage direction.
If the construction of a single core transformer is of no concern then why are there industry standards regarding the designation of the terminals? Why do we care about polarity dots when connecting transformers? ANSI standards say that when current is flowing into H1 a corresponding current is flowing out of X1 doesn't this then define a direction?
