EMT conduit systems
lectroman
Is it acceptable to add an extension collar on a square junction box, then exit the extension collar with another conduit? Example: multiple number of conduits fastened to a concrete wall using one hole straps, running horizontally. One of the inner conduits must feed a load at a certain point on the length of the parallel run. A box is inserted on that conduit for a straight feed through, and an extension collar is added to exit that junction point to install a conduit perpendicular to and over the other conduits of the parallel run. There has been a few discussions as to the code allowing or a violation concerning. Can someone set the record straight?
roger
Fl
Retired Electrician
It's legal. Just not good practice.
What about in the scenario below?
Roger
sameguy
New York
Master Elec./JW retired
Some one (480v) pull out the picture!
Yes it is fine to do, please leave slack in the box so I can get to the other wires in the rest of the pipes.
iwire
Massachusetts
Now why did I just know when I scrolled the page down that photo would be there:lol:
Amazing just simply amazing:blink:
I think the best part is when you look closely you can see that the top box and the bottom box face each other. That had to be a good trick.:huh:
