I had a call from a customer to come take down an old nichrome element heat light in his bathroom. I took the old one down and installed the new one. The problem is that the new one is slimmer than the old one and the trim doesn't cover the old hole completely. I told him that I would look to see if there is a wider trim available (is there one?), but I wasn't to blame for the gap. He is trying to hold a portion of my money (only 45 bucks) until I get it fixed. I told if I can't find the trim he is pretty much on his own, but I would try to help him patch the hole if I could. What are your thoughts?
communication with the customer before ripping the thing out of the ceiling is your best bet....
when i do stuff, i explain that if i have to make holes, i close them up, but patching and painting
is the homeowners responsibility.
i have a guy i've know most of my life who does excellent drywall work, and i pass his number along.
i had one of the heat light, fan panasonic combos... the fan is $300 wholesale. it needs a 2x8 bay to
fit into. i had to shoehorn it into a 2x6 joist, so i got some 8/4 european birch, and made a custom
frame, that gave me the thickness i needed. the panasonic trim overhangs each side of the rough in
can by a different amount, so i used floating tenons to put the frame together, dry fitted it around
the can, put the trim on, marked it, took it apart, cut each side to fit, took a 1.5" radius router cutter
in a huge router, made a bullnose on the frame, sanded it, used polyurethane finish on it, glued it up
around the rough in can, and put the whole thing up in the ceiling... ran 4" duct out the side of the
building, carefully drilling the fascia on the side of the house with a 4 1/2" holesaw.
installed it, wired it, ducted it..... patched the drywall.... it was a thing of beauty....
and then moved it 2 1/2" cause the lady who owned the house decided it just needed to move that
much. the first location had been approved before installation.
and after it was all done again..... move it an additional 1 1/4"..... for reasons i never did have explained
in a way that i understood.
that $300 fan cost $1,500 or so to install. but their was communication all the way thru, so they got what they
wanted.
