I'm assuming that you want to do this with a inlet box, back-fed breaker, interlock and cord set? What size receptacle is on the generator? Many of the ones that I've seen in that size range have an L14-30R device which would be 30 amps.
You could use a 40 amp breaker with the interlock. As said the gen. will only have a 14-30R and it should be protected by a 30 amp breaker on the gen. set. So what ever you use in the panel would just be a disconnect.
