I need to hook up some equipment that requires 208 wye. Problem is the building is supplied with 240 delta. I have never done this before...any pointers? Thanks!
If it does not require a neutral, then buck/boost transformers (Hence the name buck/boost, they can work either way) would be the most economical route, otherwise, a step down transformer, or a second 120/208 volt service would be required.
