Ground/Bond Loop
Pushpin
I have been ask to comment on a ground/bond design.
This will be a Bulk Storage Facility for crude oil. In bound product by pipeline and outbound by pipeline and truck.
There are 10 300hp pumps 8 60hp pumps and a few smaller motors.
There are 2 10,000 BBL tanks.
The equipment is located as closely together as possible.
The design has 41 3/4" x 10' ground rods all connected together. The design connects these rods in 5 rectangular patterns.
My question:
1. Does this seem excessive to anyone?
2. Does connecting the ground rods in rectangular shapes create a "ground loop" rather than a single path to ground?
The system you describe is certainly not required by the NEC. But to answer your questions directly:
1. I would say yes. It sounds like the designer is trying to create a counterpoise type grounding arrangement where every structure, component, and equipment is grounded to the earth and then bonded to each other. In any case, I can't imagine the need for 41 ground rods for ANY grounding purpose.
2. No.
My question:
The only place I have seen extensive grounding like that is for a Substation ground grid. Maybe the soil conditions are a factor...
