- Windsor, CO NEC: 2017
- Service Manager
What do you prefer for setting pole lights? If you had a forklift on site that you could use for an hour to complete the task, would you call out a crane instead?
Thanks for the replies, guys. Situation is a flat surface, 25' steel poles, Lull-style (but the other brand, I think) big honking forklift.
So if a forklift is used can it be operated by the electricians? What I mean is ..... Does someone in the crew usually have the experience to use it and set the pole? Not that it takes much I was just curious. Thanks
