How many conduits can penetrate a 4x4 box before you have to add an extension ring.
clcurtis
New member
Raeford,Nc
I have been trained once you penetrate a 4x4 more than 4 times you have to add an extension ring. Now I have been told that it in not required. What is propper etiquette.
Sierrasparky
USA
Electrician ,contractor
I suppose you were tought a general rule of thumb, The code does not work that way. You go by wire fill and each conductor counts as per the tables , the grounds usually count as 1
